sidepod
- Messages
- 7,573
- Vehicle
- T4 PopTop
Yes you’re right but there is a reason a full electrical test is required by the IEE.Pressing the test button classes as a mechanical test on test sheets bit It also tests the tripping mechanism electrically by causing a small current flow imbalance sufficient to trip device.
A full electrical test is obviously better but the simple push test will check its working electrically and mechanically in its basic form.
Go into your socket on the side of your kitchen unit. Disconnect the earth. Now press the test button. Yup it still works but now you have a van that could kill you.
