Aca_chap
The existing ones are fine. It’s straighforward and works.Do all the straps that are on the bag attach to the bike frame ok , or do you need additional straps ?
Ordered it all this afternoon - thanks for your help.The existing ones are fine. It’s straighforward and works.
Hi SupdubTried to get this set up twice this weekend.
Can’t get the rack to clamp onto the ratchet so the key can be turned and it lock. The picture shows as far down as I can get it. Seems close to the first ratchet.
Any ideas what is going wrong?
Pictures this time...
Hi. Yes it is - had a fitted a couple of weeks ago for this.Hi Supdub
is your tow bar new ?
My handle was pretty darn stiff the first time I used it (oh dear!)Thanks. I’m sure it’s cupping the ball correctly - got a clear green ring. I’ve released the handle on the way down. It should click as it gets in the ratchet but it doesn’t get quite far enough - it is so close when I look underneath. Key won’t turn without it being in one of the ratchet positions.
Here’s the man in the know!Its because the ball is new, the paint thickness is the difference between fitting and not.
mount the rack and clamp the handle down so the ball socket grips the ball, twist the whole bike rack from side to side, this will remove a line of paint where the socket clamps the ball, get some wet and dry and remove the paint in the area where the rack socket has marked the tow ball.
refit and try again.
similarly spray the ratchet etc with some silicone spray as they can be stiff when new, but the problem is with the paint on the towbar ball.
Just leave it attached and pointing downwardsWet and dry sandpaper worked! So pleased - thanks again.
One more question. What do I do with the long arm if I only want to carry two bikes?
I am quite happy putting a Brandrup Flexbag (the wider one designed for a T5) rack on my Atera DL3 - works really well and can still take 2 bikesHi,
I have a Atera Strada Sport M3. I'd like to add this bag https://autofix.nu/produkter/972-an...taet---kapacitet-566-ltr---maal-152x61x61-cm/
Since the wheel positioners cannot be removed do you then add the bag on top of it ?
and that is without taking the wheel clamps off right ? The bag sits on top the clamps ?I am quite happy putting a Brandrup Flexbag (the wider one designed for a T5) rack on my Atera DL3 - works really well and can still take 2 bikes
Yes, has been absolutely fine. I have generally used soft bags on the bottom of the pile in the bag which allows the bag material to adapt to the wheel holders underneath. No issues experienced with rubbing etcand that is without taking the wheel clamps off right ? The bag sits on top the clamps ?
Sound good, you don't happen to have pictures how it looked do you ?Yes, has been absolutely fine. I have generally used soft bags on the bottom of the pile in the bag which allows the bag material to adapt to the wheel holders underneath. No issues experienced with rubbing etc
Though you cannot take off the straps, the straps move/rotate. Can you not rotate and clip them under the rack and use the bag on top? They then stay out of the way. I do this often when I have to carry something other than bikes on the rack.S
