Alan Andrews
Hello,
I'm after a bit of advice.
My 2017 Ocean has not been used during the lockdown. Everything was good beforehand.
I have regularly put the Cali on electric hookup for a couple of days each month.
I have today gone to start the Cali and notice that the battery warning light is lit.
I suspect the battery may be the problem, so I have just put a spare battery on charge. I will swap it over tomorrow to see if it makes a difference. Although the Cali has started without issue throughout.
What other items could be the cause of this?
Does it point me towards the engine battery only? Or does the battery generation light also cover the leisure batteries?
I guess that the other prime suspect is the alternator.
What about the battery shunt on the battery negative terminal?
Are there any fuses that could have blown?
Does anyone have a Battery Generation circuit diagram I can refer to please?
I do have a solar kit to install, but I want to get this sorted beforehand.
Any wisdom will be much appreciated.
