V
vbk1975
I've look at everything back in this thread and to see if I had any note but I cannot find which Fuse turned off the Kitchenette light, sorry.
You could do some trial and error by pulling a fuse at a time from the set under the passenger seat and seeing if the Kitchenette light goes off? I used this diagram from Loz https://vwcaliforniaclub.com/attachments/75300/ and I'm sure it was one of the Fuses labelled as for lights.
Do be careful though when you do it as it's a tight space and I did lose a fuse down a crack at one point. It's simple and cheap to get a new Fuse but obviously takes a day or so unless you have spares to hand.
Good lucki
So I would pull fuse SH16, this powers a small electronic latching circuit for the kitchen light switch, has other stuff on it like the DC charger. If that doesn’t work then pull SH16 and SH18 together. SH18 is the main interior lighting ecu, that controls the dimming of the roof lights and kitchen lights. It is almost certainly the latching electronic device has locked on, it is there to make the momentary push button operate like a normal switch from what I can determine from the circuits.I've look at everything back in this thread and to see if I had any note but I cannot find which Fuse turned off the Kitchenette light, sorry.
Good luck
