v-tec
- Messages
- 169
- Vehicle
- T5 SE 130
Hi all
You may have read on a previous post (Charger fuse location) that my battery charger under the fridge has failed (internal fault)
So I’m considering 2 options
1) Replace the charger (and possibly relocate to a cooler place)
2) Or don’t spend £300 on a new charger and fit solar system,
My question is, it’s my under standing that when charging 2 battery’s that are wired in parallel the correct way to connect the charger (or solar supply via controller) is to connect the positive to 1 battery (say the rear) and the negative to the 2nd battery (in my case under the passenger seat) This is so they get a balanced charge (am I correct)
As you can see in my photo the plug that is circled is the DC plug that is connected to the charger output plug, (This plug has battery voltage at it)
So if I decide not to fit a new charger, what would be wrong with fitting a VW female plug to the ends of the solar wires and plugin it in to the existing connector (circled )
The problem is I don’t have a proper VW schematic wiring diagram of this circuit,
Any help please from someone with good knowledge,
Many thanks.
Many thanks.
