mwpmorris
Hi, hoping someone might be able to help.
I’ve installed an underseat (driver’s) subwoofer in my T6 Beach. I’ve taken an ignition feed from an empty space the main dash fuse box, and used it as the main power supply and ignition switch so that it’s only on when the ignition is on. Trouble is, I’m now getting a stop / start error every time I start the van.
Pulling the fuse solves the problem, swapping the cable into a different empty socket doesn’t.
Fist of all, is there a quick fix for this? I’m guessing the computer is detecting an unusual current draw off the starter battery and throwing things out. Does something like this need coding in somehow?
Failing that, I guess taking my main power feed from the leisure battery is my next port of call. I did have a poke around under the passenger seat but couldn’t find a permanent “on” as I’d expect from the leisure battery. Any pointers here?
Many thanks!
Many thanks!
