john eagle
Eaglehead
Hi I am in the process of getting a 2017 T6. How does the adblue work and how often does it need to be added?
Have a read of this attached fine self-study guide.Hi I am in the process of getting a 2017 T6. How does the adblue work and how often does it need to be added?
Most seem to top up every 4000 miles or so, a warning notice appears that advises 1200 miles to go before running out. I top up at a local Shell garage commercial pump at about 70 p a litre, takes about 10 litres at a time. There have been warnings on this site about overfilling but not normally a problem if you stop at the first click of pump.Hi I am in the process of getting a 2017 T6. How does the adblue work and how often does it need to be added?
Great help thanksHave a read of this attached fine self-study guide.
| Specification | Minimum | Maximum | Weight |
| Urea Content | 31.8 | 33.2 | % |
| Density 20°C | 1.0870 | 1.0930 | g/cm3 |
| Refracting index 20°C | 1.3814 | 1.3843 | |
| Alkalinity as NH3 | 0.2 | % | |
| Biuret | 0.3 | % | |
| Aldehyde 5 mg/kg | 5 | mg/kg | |
| Insolubles 20 mg/kg | 20 | mg/kg | |
| Phosphate (PO4) | 0.5 | mg/kg | |
| Calcium | 0.5 | mg/kg | |
| Iron | 0.5 | mg/kg | |
| Copper | 0.2 | mg/kg | |
| Zinc | 0.2 | mg/kg | |
| Chromium | 0.2 | mg/kg | |
| Nickel | 0.2 | mg/kg | |
| Aluminium | 0.5 | mg/kg | |
| Magnesium | 0.5 | mg/kg | |
| Sodium | 0.5 | mg/kg | |
| Potassium | 0.5 | mg/kg |
DONT overfill, although you can wash it off, it MAY cause a fault, has been discussed at length on here.If you overfill, it won't do you any harm. Its's animal urine, so just make sure you wash your hands afterwards!
How / Why?
How / Why?
That's okay.Sorry, above wasn't meant to be blunt. Just curious as I work for a Ship Owner where some ships use Scrubbers to 'clean' emissions (some similar to using ADBLUE) so interested as to how it might cause an issue. Cheers, Dave.
I agree its a pants idea, but some have fallen foul of it..So a trip to the dealer to reset what seems to be a basic level sensor, would assume that the actual dosage is not impacted by accidental overfilling(some might say easy $$ for some.). Wouldn’t wash in my industry as the end users would kick back. Will step off my soapbox!
As a rough estimate, I fill the AdBlue tank about once every ten diesel refills. I use a commercial vehicle AdBlue pump at a local garage.Hi I am in the process of getting a 2017 T6. How does the adblue work and how often does it need to be added?
Adblue is injected directly into the exhaust system to assist in the Nox reduction process. it basically aids the system to clear soot deposits out when it turns to ammonia in order for the emissions system to be fully functioning.Hi I am in the process of getting a 2017 T6. How does the adblue work and how often does it need to be added?
Thanks very much, thought it was worth a quick post just to add any extra information to the already mentioned Q&A here on the forum.There aren't many producers of Adblue but without research it would be hard to trace any particular Brand. I'd stick to the more well known sources as in annual terms you aren't going to save much by shopping around.
Cheapest are forecourt pump sources such as Shell. Other sources such as Halfords do special offers at times.
I may be wrong but I'd say that Kemetyl merely package and distribute Adblue rather than manufacture it. You'd be paying more than pump price by as much as 90% for a 10 ltr fill up.
Like every product these days Adblue will attract the quick buck brigade.
Will take a trip out to Halfords tomorrow, Screwfix 10 litre at £11.99 were out of stock, so got 5 litre as I am getting low.Will stock up ready for next time ! Thanks B J GHalfords currently £12.50 for 10ltrs or £18.75 for 2 x 10ltrs.
Shell main/large forecourts have an Adblue pump in the HGV area.
I believe that AdBlue has a shelf life of c,18 months.Will take a trip out to Halfords tomorrow, Screwfix 10 litre at £11.99 were out of stock, so got 5 litre as I am getting low.Will stock up ready for next time ! Thanks B J G
