Wanted VW Holding Strip / Awning Rail for Hexaway Kador
NRDSRFR
NRDSRFR
Tynemouth
T5 SE 174
Hi,
I bought a Vango Hexaway awning and from brief research I believe I need one of these VW rubber strips which fits the rail so I can attach it using a "kador" (I don't know if kador is the rail, the figure 8 strip or both!)
Does anyone have one to sell for cheap, assuming this is the correct part?
You will need a kador kit comprising of 3 strips of figure of eight and some double sided kador also you will need the vw strip all available in the club shop
Thanks! that was much cheaper and worked great. Just had my first go last night!
How do you find the Hexaway? I’m sorely tempted but was concerned that the sliding door wouldn’t open all the way without catching on the tunnel.
Any thoughts/comments/suggestions gratefully received!
We really like it. You do have to pull the tunnel away from the van a little bit to let the door slide past it when you open it but it’s not a big issue. I’m looking forward to using it in the summer with the two large doors open to get airflow through
brad63
Ali Luckman
SailSki
SailSki
SailSki
Morganic
7K
Ed Bryant
Ed Bryant
