Rear badge on T6
Richard Hurst
Richard Hurst
Hatfield
T6.1 Ocean 150
Hi Everyone
I’ve removed the front grill badge prising the clips out slowly. I want to remove the rear badge but not sure if that’s fixed on the same way or it is just glued on?
Glued on heat it with a hairdryer then it should lift off
Ok will give it a try. Doesn’t look glued on though.
Mine was glued what year is your van?
Mine is clipped on (2018). Can be gently lifted off with a trim tool.
G
6K
Grant white
G
Richard Hurst
Richard Hurst
Richard Hurst
Richard Hurst
Handsome-Sym
Handsome-Sym
Roc1
Californication69
Californication69
Volkywagen
Volkywagen
Volkywagen
