Richard Hurst Messages 383 Location Hatfield Vehicle T6.1 Ocean 150 Oct 28, 2018 #1 Hi Everyone I’ve removed the front grill badge prising the clips out slowly. I want to remove the rear badge but not sure if that’s fixed on the same way or it is just glued on?
calikev Administrator Admin/Founder Messages 16,157 Location Kettering Vehicle T4 PopTop Oct 28, 2018 #2 Glued on heat it with a hairdryer then it should lift off
Richard Hurst Messages 383 Location Hatfield Vehicle T6.1 Ocean 150 Oct 28, 2018 #3 Ok will give it a try. Doesn’t look glued on though.
Richard Hurst Messages 383 Location Hatfield Vehicle T6.1 Ocean 150 Oct 28, 2018 #4 Vale46 said: Glued on heat it with a hairdryer then it should lift off Click to expand... It’s actually clipped on.
calikev Administrator Admin/Founder Messages 16,157 Location Kettering Vehicle T4 PopTop Oct 28, 2018 #5 Mine was glued what year is your van?
Richard Hurst Messages 383 Location Hatfield Vehicle T6.1 Ocean 150 Oct 28, 2018 #6 Vale46 said: Mine was glued what year is your van? Click to expand... 2018
calikev Administrator Admin/Founder Messages 16,157 Location Kettering Vehicle T4 PopTop Oct 28, 2018 #7 Must of changed the T6 then
s2bear Top Poster VIP Member Messages 992 Location london Vehicle T6.1 Ocean 204 4 motion Nov 9, 2018 #8 Mine is clipped on (2018). Can be gently lifted off with a trim tool. Sent from my iPad using Tapatalk
