leightonjthomas
The first awning split was about a foot long and the awning was replaced under warranty. The replacement awning soon started to split very slightly on the outside. My local garage (BMVS) glued it together and clamped it overnight - free of charge. Not sure what glue they used but it’s now held for over three years. I checked with VW about whether it was covered under the extended warranty in case it started to split again. As it’s not covered I’m just keeping an eye on it, especially in very hot weather, and if necessary will try adhesive again if it’s not too bad. I always carry with me the repair kit from the Club Shop. If it doesn’t work I’ll buy the fabric from the Shop for £272.95 and get BMVS to fit it. It seems almost criminal that they’ve been replacing the whole assembly under warranty every time the fabric splits.When my 3 yr warranty expired I thought about extending it but it was so expensive it was worth taking the risk. Did you say you repaired you awning yourself?.
Anything is worth a go. I’ve got vinyl glue but who knows until you try it. I know superglue would work but it goes hard and not flexible and superglue is FINAL. Absolutely no having a second go.
