Pete M
I've had problems with opening the overhead locker since new, I assumed it was over dampened but after finding info on here it seems the hinge needs a bit of a tweak, this weekends job.
The problem I have is I've managed to dislodge/partially remove the righthand pivot pin on the catch that you pull to open the locker.
Wondered if anyone else has had the same problem and managed to fix it, if so a heads up would be cool
before I go scratching my head over it.
Cheers
Cheers
