V
Victor
Guest User
I don't think it does, head light wash was an optional extra, which I didn't tick
As mentioned above, you do have the washers, its the rectangular cut out just below
Yes, you definitely have the washers
Its like a mini jet wash, but the little and often approach does seem to keep them clean.How does spraying a bit of soapy water on a headlamp wash it with out wiping??
Is there a little man that lives in there also with a sponge?
Maybe I'm a bit stupid but if you don't wipe it won't clean anything off???
Pretty Useless really...a bit of rain would do the same job,and in the uk we have plenty .led lights are cool but £1500 wow Vw you should wear a mask and hide in the bushes on a highway!!!!
I hope soInteresting - I am sure the configurator online adds them FOC but that doesn't mean anything does it!!
Use a separate High Pressure Pump, not like the Windscreen washers.How does spraying a bit of soapy water on a headlamp wash it with out wiping??
I was under the impression that LED and Zenon headlights 'must' have washers and self levelling.Just an observation
My 2017 Ocean that has LED head light foes
not have headlamp washers
I know this,I have owned cars with themUse a separate High Pressure Pump, not like the Windscreen washers.
I have LEDs on my 2017 Ocean, washers are fitted... pointless without wipers though!!I'm picking up my new (ish) 2017 MY it has LED so I will let you know if it had washers.
Why is the California so expensive?
