Sonas
Why are LED`s so expensive. Can they be retro fitted?
Sonas
Sonas
Yes. Over £3000 + VAT in U.K.Why are LED`s so expensive. Can they be retro fitted?
Sonas
How does this help? You need a lot more than a headlight...
Are the ozrams just a straight swap?Personally, having fitted Osram Nightbreaker bulbs, if have no problem night driving on Main roads or country roads at a safe speed. Its more about the intensity and spread of light rather than just how bright they are. Too bright and you lose peripheral vision. Horses for courses .
yes.Are the ozrams just a straight swap?
I think these are the ones I swapped standard drls for. Not as cool white as LED but definitely whiter than standard.What about drls...?
I changed the standard to bright white LED, can't remember the make. However, since the change the DAB radio doesn't work unless I switch the main lights on and the drls are then turned off.
Any recommendations for drl replacements which give the white look instead of yellow...?
Just an observationSo in answer to the question of why they are so expensive.... because they are crash tested CE marked lenses, designed to limit blinding and the LED electronics are tested for EMC interference with other components in the vehicle (so DAB still works). LEDs also come with headlamp washers.
Interesting, show us a photo...Just an observation
My 2017 Ocean that has LED head light foes
not have headlamp washers
Why is the California so expensive?Why are LED`s so expensive. Can they be retro fitted?
Sonas
Is it. Have you priced up a base Commercial van with the exact options, that relate to the vehicle only, as you have? Probably a Caravelle would be the nearest base to start from.Why is the California so expensive?
The washer is in the bumper, the little thing beneath the light in your photo. It slides out and sprays the headlight. Mine operate automatically every 5th time I operate the windscreen washer. It just sprays, no wiper.
The washer is in the bumper, the little thing beneath thno it doesnt, e light in your photo. It slides out and sprays the headlight. Mine operate automatically every 5th time I operate the windscreen washer. It just sprays, no wiper.
