shaunchivers
I have located the source of water in my passenger footwell to be a detached hose from the grommet part that tube connects to (Drain Tube - part 6X0877236A). This is the drain hose that runs from the frontside drain hole down the pillar. Not too difficult to find the culprit as the drain tube part fell out when I removed the lower dash panel!
My question is what is the best/easiest way to reconnect the hose and fit the drain tube. I can just about get one hand up and feel where it all needs to go but I am going to need to create more room for a second hand. Can the passenger side lower dash be removed easily without setting off the airbag?
are you not still in waranty
