The packet says (in German) "1 set", not "1 piece"there's 2 in the pack but the packet says 1 on it.
Anyone point me to the thread that had a similar hack for the SE/Ocean? It was a little extra platform that slotted in the end of the kitchen and dropped over the lock pin on the front door (from memory).
There is also the 'ikea chopping board on top of the cutlery tray' trick.
You have what I want! I've been looking for something to enable me to make the morning cuppa without opening the door or putting the bed away, this is brilliant. I'm going to order the rail clips tomorrow. If you have any more pics or advice on how you fixed it together then it would be much appreciated :0)We made this for our 2 seater Beach it stays up all the time great for brewing tea or drinking wine. We are able to make the downstairs bed with it in situ so hubby can make morning tea while I stay in bed.
HiI am currently working on something similar at the moment as a project to "justify" me getting a 3D printer
Will be giving the prototype a test run this weekend at the meetup but already found an issue with flex so will not be putting much on it.
Pic of the bracket. Printed 2 and using a bit of scrap wood so can work out the details.
View attachment 21713View attachment 21714
Hi SE VanmanYou have what I want! I've been looking for something to enable me to make the morning cuppa without opening the door or putting the bed away, this is brilliant. I'm going to order the rail clips tomorrow. If you have any more pics or advice on how you fixed it together then it would be much appreciated :0)
Hi again the table top is 400mm by 450mm, brackets are on the short edge. I have included some pictures showing position of brackets and leg, if you do not want the access into the box both can be positioned the same distance from the edge. We used a piece of wood with recesses chiselled out to accommodate and secure the bracket. The leg is telescopic and folding so table can be stored behind the seat or elsewhere. One picture shows how far it sticks out in relation to the front seat so you could have it longer if you wanted. Thing to be mindful of, make sure you can slide the table forward enough so the leg positioned does not interfere with the making up of the bed.You have what I want! I've been looking for something to enable me to make the morning cuppa without opening the door or putting the bed away, this is brilliant. I'm going to order the rail clips tomorrow. If you have any more pics or advice on how you fixed it together then it would be much appreciated :0)
Thank you BeachyBird, this is exactly what I had in mind, I'm surprised its not already available off the shelf. I've ordered a tabletop, telescopic leg and I picked the clips up from my dealer yesterday....£12 per pair now, but essential. Yes I have the two seat Beach too, and would like to keep access to the box while the table is up, so your pics and advice are invaluable - thank you again for taking the time to do them and show the detail, I'll post some pics once I've got mine together. :0)View attachment 29027 View attachment 29028 View attachment 29029 View attachment 29030 View attachment 29031 View attachment 29032 View attachment 29033 View attachment 29034 View attachment 29036 View attachment 29037
Enjoy your first tea in bed without stepping outside.
Hello Cali Fate - I love this idea, I hadn't seen it before. If it could be made to fit the VW Rail then I'm sure they would be very popular. Slightly bigger to hold a couple of mugs would be a bonus. I'm currently going down the table and leg route for stability as I'm paranoid with 2 kids and a dog on the way, the thought of a burner an boiling water hanging on the side will make me nervous. Please update if you get anywhere with this as I'm sure there will be a lot of interest.I have been thinking about something similar - Maxxcamp have made something close to it, but it is designed for their rail profile which is different to the Beach rail profile. I have purchased one from Maxxcamp, and in the process of getting a local metal basher to make one that will fit the Beach, and mount the gas stove.
The idea would be for it to be reversible - allowing you to clip it on in either the horizontal mode for operation and vertical mode for storage.
Having seen this thread, if the unit was slightly wider might be a bit more useful - cups etc. Would there be enough demand to produce a limited run ??
SE VanManThank you BeachyBird, this is exactly what I had in mind, I'm surprised its not already available off the shelf. I've ordered a tabletop, telescopic leg and I picked the clips up from my dealer yesterday....£12 per pair now, but essential. Yes I have the two seat Beach too, and would like to keep access to the box while the table is up, so your pics and advice are invaluable - thank you again for taking the time to do them and show the detail, I'll post some pics once I've got mine together. :0)
This is the code for the replacement table brackets you get them from your VW dealer normally they need ordering, they come as 1 pack which includes 2 brackets approx £12 now.I like the idea or a shorter table. I have searched for the part V7E7 898 209 online and failed, can you remember where you brought it. Thanks
Hi Gazellio they are NOT VW parts the telescopic leg I used is a Reimo you can pick them up from most accessory dealers and on eBay approx £22. And table top was made by a converter who does his own cabinet making. Not sure where SE VanMan has sourced his from.Hi, Can I ask where you ordered the Table Top & Telescopic Leg from not sure if they are VW parts - have reread thread and still cannot work that out![]()
Hi I went to clearcut conversions online, they have a choice of table sizes and finishes, I went for 400mm square. I asked for a telescopic Reimeo leg and it came fitted to the top along with two clamps which would hang the table on a ‘conversion style’ bar. My plan is to modify the supplied clamps to hold the VW parts... off to the shed!I am seeing a 've conversion company about making them tomorrow...
Hi SE VanManView attachment 29237
looks good. but would look even better if anodised. This could be done by your local metal finishersMy husband and I have made a side table for our 2016 beach.
It saved us getting the big table out, and is handy for making a brew, putting your drink on or a lap top on to watch dvds.
It's made from aluminium with rounded corners and 2 cup holders for our ecoffee cups.
It fits perfectly in the table slot holder and does not slide about.
Easy to store in the back pocket of the front seats.
Not ideal for sitting on but it's fairly robust and my drink doesn't slide around on it very much.
Ideal for the kids to play a small board game in to.
I'm really pleased with the outcome.
I also make the VW cushion covers if you go to handmade in Haworth on face book.
What do you guys think to it?
