MattBW
Here to help
I had the same problem when my beach was new, it just wasn't charging the batteries. I even had a voltmeter plugged in and it was hovering around the 12.3-12.5 (which I think is float charge?). At the same time the stop start wasn't working.
I did a lengthy charge on hookup and then a diagnostic with an OBD reader and it started working after that.
Later I found out they had changed the AGM leisure battery for a lead acid which makes me wonder if thats part of the issue (different voltage requirements for AGM?) . I don't know if this caused problems or why it happened to be honest but in my case it was I think software not hardware.
