Stuart
- Messages
- 613
- Vehicle
- T6 Beach 150
I will be when my Beach arrives. I've already got a massive tarp from MachineMart (UK shop). Not actually sure on the size but it should be easily big enough.
We carry 2 fold up bikes. We bought a few of these bags they come in different sizes and are cheap and handy for all sorts. https://www.amazon.co.uk/gp/product/B00ADU5AAW/?tag=unique09f-21
HI Paul,Just a follow up from me as the initial post in this thread -how time flies! We've now had 2.5 years of cycle events with the Cali. We regularly carry 2 bikes ( and more sometimes).
a) two inside can go one rear wheel between two from seats (and secured with a strap to the armrest) . Just requires driver seat sliding forward to get in and out. If required a second (small/med) bike will go front wheel on rear seat and rear wheel adjacent to cupboard under sink. Works a treat!
b) If bed not to be used, rear shelf removed, bench seat fully forward (stops removed) can fit 4 bikes in rear, wheels on.
c) and if all else fails, the VW rack is just brilliant. I've used maybe 6 big racks in my time (including the Atera Strada) and for my needs ...regular use etc, the VW rack is far and away the simplest and best.
And of course, for folders, Bromptons are fantastic.
Hope that's helpful. The Cali is brilliant as a cyclists vehicle.
Paul
Here's a picture of two bikes inside the Cali with seats on the standard position. After moving driver seat forward to get them in, The first goes rear wheel first between front seats and then front wheel on rear seat to move rear wheel to against LH seat. The second goes in the same way but stays on the floor. Usually a blanket between them and rear part of frame straps to Nearest armrest. Works absolutely brilliantly for those bikes that really need to avoid getting wet and dirty outside. I can definitely see my carbon road bike going inside for the shorter trips, especially the ones based on getting some serious riding in. Will probably stick a lightweight cover I have to protect the seats.View attachment 15326 Here's a picture of two bikes inside the Cali with seats on the standard position. After moving driver seat forward to get them in, The first goes rear wheel first between front seats and then front wheel on rear seat to move rear wheel to against LH seat. The second goes in the same way but stays on the floor. Usually a blanket between them and rear part of frame straps to Nearest armrest. Works absolutely brilliantly for those bikes that really need to avoid getting wet and dirty outside.
Ours are relatively small light bikes.
Hope that is helpful
It's an option, most of the time especially on tour I shall have three bikes on the tow bar rack. However on occasions I will be out for day trips or perhaps an overnighter where I will be out riding and my better half will be picking me up in the Cali. On these occasions it will be handy to just stick the bike in the back. Add to that the road bike lives in my flat and it makes sense for me on occasions as an option.Out of interest ( this isn't a criticism) why do you want to carry bikes inside your Cali...? My view is that they are bikes (we ride a lot and look after out bikes etc), they can get wet, can get dirty but nothing a good wash and lube doesn't sort out....or am I missing something?
very good. i wonder if it would fit crossways behind the back seat in a Beach (no cupboards to get in the way.Just adding my solution to carrying one bike internally - have found that the “EVOC Bike Stand Pro” is a perfect fit for the rear cabin - rails are perfect length and just wide enough to provide stability in most scenario, saddle then touched side of front seats if cornering aggressively. Could get a t-bolt for the rail and tie it to that for extra safety if felt necessary. It’s about £115.
Works for Road / Gravel / Mountain bikes too.
Would suggest also getting a chain cover just in case brush it against seat when putting it in van, but not essential during travel.
Won’t be the solution for everyone but hopefully helps in certain scenarios.
You can still safely use one of the rear seats with a road bike, but flat bars would sit in front of the off side rear seat also given their wider width (albeit you could remove them and Evoc also do a separate item to strap unattached bars to the frame).
