Sorry Now Sold Westfield awning, advanced air system. Aquila 320High top
Californication69
Californication69
Bill
UK
T7 Beach
Aquila 320
High top, adjustable 2450 to 2800mm
Footprint 3200 x 3400 mm
Fits awning of >3.2m
24kg
Inc pump,
Brand new, never used.
£349 ono
I don’t have any photos of it on my Moho, as I never took it out of the box. Brand new from TMD Motorhomes on 1st August.
Warranty until August 2026.
Westfield Outdoors Aquila 320 high top Awning
A performance motorhome air awning packed with technology features and additional options. It features the patent pending Advanced Air System which not only gives you ease of use reliability but the option of single inflation or the strength of storm poles. The two large scenic windows give you the perfect outlook and allow an amazing amount of light inside. The oversized canopy is large enough to have a table and chairs under allowing you to really get outside but retain the cover from the elements. The use of the excellent Hydrotech SP fabric means you get the perfect balance between strength and weight making it easy to use and very durable.
The Advanced Air System AAS is a next generation air tube system. It has been created to give you the cost saving benefits of an independent system along with the additional benefits of a single inflation system.
The system uses 3 layers for strength and stability. It has the internal bladder which is the part that you inflate. You then have a PE cover that adds protection to your bladder and aids stability. You then have a sleeve which is sewn into the awning which adds a final layer of protection and stability.
The advanced air system also benefits from an extra re-inforced PE cover. This makes the PE cover stronger particually in the corners and bends. This not only improves the protection you get from the PC cover but also the stability of the awning as the tube is held in place and position better.IMG_0089.jpeg
headsuk
headsuk
headsuk
Anthony1
Anthony1
Anthony1
