Water leak at centre of rear bumper / step
bods
Uk
Grand California 600
Hello
Just filled up with fresh water and now notice water is leaking at the centre of the rear bumper / step. It looks like it is leaking from within.
Any ideas what could cause this?
Hello
Leak from Water filler to Water Tank connection?
In which case it should stop, but if it continues then Water tank or water tank drain?
The water
We saw the leak last night and it has continued overnight. Water flow in the van seems fine, but would really like to understand what's causing this. Is the water tank drain the one above the rear wheel?
Looking under the vehicle it looks like some pipes/hoses may go into that void in the step.
Ok. Taken a closer look and the leak is actually on the rear left - there's a small trickle there. Possibly related to the feed to bathroom or boiler?
And... Found it. It is the cold water feed to the bathroom tap. There's a monster thread about that already...
