Vibration at very low speed
D
davejmulholland
switzerland
Hi all,
I have tried to read all the threads on vibration, but none really match what I am experiencing.
2019 T6.1 Cali 4 Motion with 100,000km's:
On take off there is a very low sounding vibrating / rumbling that can be felt on the drivers side through the floor / brake pedal and the steering wheel.
At more than 4 or 5km/h it disappears instantly.
There seems to be no pattern, it happens when driving straight, turning, braking and accelerating, but not all the time.
If you are very delicate with the accelerator you can get it to replicate, but it is difficult to "hit the spot".
Has anyone experienced this, or does anyone know the cause?
Thanks in advance,
Dave
CV joint or suspension bushes? Maybe.
Potential Haldex clutch issue? Scanned for codes?
100k, I’d go bushes.
My Saab vert is 17 years old, made some weird vibrations and noises.
Polybushed every bush.
It drives like new now.
Driveshafts ?
Clutch
Engine mounts
Bearings.
So many things wear !
Hi all,
Thanks in advance,
Dave
I would start from basics.
Check tyre for any abnormal wear.
Swap front wheel to rear.
Jack up and check for any excessive movement of wheel vertically and laterally.
This would isolate the problem to tyre/wheel or suspension.
Hi all,
Thanks in advance,
Dave
Maybe a binding brake, which frees up once driven and nudged about
