Accessories For Sale Tow Bar Folding Bike Rack Uebler i21Z
Californiadreamin
Rhondda Cynon Taff
T5 SE 174 4Motion
For sale a Uebler i21Z folding, towbar bike rack, used just the once, still in original box.
  • Tilts to 90 degrees, making it suitable for vans with vertical top-hinged tailgates - i.e. Volkswagen T5, T6.Tilting is done via a foot-operated lever, so both hands are free to hold the outer bike and lower until it reaches the tilt-stop, you are then able to get between the bike rack and into the rear of the van.
  • Fits any type of tow ball and is fitted and removed when folded, therefore minimal strain on your back. The tow bar fitting system includes a green indicator which shows when the rack is correctly fitted on the tow ball.
  • Weighs 13.5kg and will carry 2 bikes of any type, up to a maximum wheelbase of 130cm. I bought it for two electric bikes weighing 19Kg each.
  • Folded dimensions are W61 x H20.5 x D69cm - small enough to fit into the van when not in use, reducing the risk of theft when you're out on your ride.
  • Comes with the 'Z' ratchet strap bike holders, ideal for chunky eBikes.
  • Everything is lockable; the rack is locked to the van and each bike is locked to the rack, all using the same key
  • Lights are 13 pin ‘5 function’, including fog lights and a reversing light. I will throw in a 13pin to 7pin lighting adapter if needed
  • This bike rack is engineered and built in Germany and arguably the best on the market
You are able to position the bike holder arms wherever they can get a good grip on the bike frame or seat post. Each bike holder arms include a long reinforced lockable strap and protective padding to protect the frame of your bike. Maximum bike frame diameter for bike holder arms is 115mm round tube, 120 x 80mm rectangular tube, 95 x 95mm square tube. The wheel tray centres have a wide 240mm between them, making it easier to carry chunky downhill MTBs and eBikes, and reducing the risk of the bikes rubbing together. The wheel straps can hold tyres up to 3". Reluctantly selling as now upgraded to a Motorhome with bike rack already fitted and no towbar.
Selling for £600 - Retail price £720. I will also throw in the storage bag (never been used) for the folded back rack (retail price £60.00). Buyer to collect from Cardiff area
YorkshireWander14
OxonCalifornia
O
Alex Currie
Alex Currie
Alex Currie
MarkG
Accessories For Sale Atera bike rack
jonddd
