P
Paul Roe
My t6.1 ocean 4montion 1600 miles on the clock and got a tyre pressure warning alert but all tyres seem ok. Does the t6.1 use abs sensors like the t6
How do i know if its got the upgraded TPMS ?It does, unless you have the upgraded direct tyre pressure monitoring option.
All i can see is an option to reset the alert so i guess i dont have the active TPMS, can the active TPMS be retro fitted on the t6.1?I'm not in my van at the minute but if you go into vehicle settings - tyre pressures you'll see actual tyre pressures for each tyre if you have TPMS
The Indirect ABS tyre pressure system reacts to a drop in pressure because the tyre circumference decreases so more wheel revolutions / mile compared to the settings. BUT it can also be triggered by decrease revolutions / mile caused by over inflation.My t6.1 ocean 4montion 1600 miles on the clock and got a tyre pressure warning alert but all tyres seem ok. Does the t6.1 use abs sensors like the t6
Low / High tyre pressure warning or a system fault?My t6.1 ocean 4montion 1600 miles on the clock and got a tyre pressure warning alert but all tyres seem ok. Does the t6.1 use abs sensors like the t6
my last cali started getting this at around 50000 miles my new one is doing it at 1600 miles !Low / High tyre pressure warning or a system fault?
If it is direct TPMS, normally with hard alloy valves, then the signal can get blocked by poor quality 12v chargers or dashcams, this would result in a system error or blank tyre pressures.Low / High tyre pressure warning or a system fault?
