Arron b
Thanks for the reply’s guys I’ll have a good read of the instructions. An getvthe courage to fit it. Is the anything needed for adding a second panel with this setup?
Any pics of were your Epever is mounted
It’s in the top of the rear passenger side cupboard. The one that you can get to when the tailgate is open, as shown in the instructionsAny pics of were your Epever is mounted
Roger will go the extra mile to help.Looks like a Roger solar camper solutions kit.
Brilliant bit of kit.
Check out some posts from Roger
Search is your best friend.
Solarcamper solutions.
Four more observations and I’ll let you get on with itThanks for the reply’s guys I’ll have a good read of the instructions. An getvthe courage to fit it. Is the anything needed for adding a second panel with this setup?
Does it? I have the same controller and have been told I need one with a dual battery output to charge the engine battery as well.EPEVER controller charges the van battery too
Bought mine from Roger and it most certainly does charge both, only when the leisure batteries are full thoughDoes it? I have the same controller and have been told I need one with a dual battery output to charge the engine battery as well.
Yup - Roger did warn me it was a bit pants really for charging starter and in reality, it is. There is a newer one that I’ll look at that has more flexible parameters, but in reality it’s never really been an issue.Bought mine from Roger and it most certainly does charge both, only when the leisure batteries are full though
