Shower fuse identification/Location
Paul White
Paul White
Herefordshire
T7 ocean
Looking for help in locating the fuse for the outside shower. The sink tap water flow is fine.
A photo would be ideal.
It's the same pump so fuse is fine if tap runs. It will be the ball valve or the rear switch. Try reattaching shower head and shorting the switch
I isolated the switch, checked continuity with meter whilst actuating the switch, all good.
Explain ball valve.
I’ve checked for electrical power by removing both wires and there is none.
Dealership service Swansea believes that there are two fuses, one for sink and one for shower
I believe the fuse box for sink and shower is located beneath the sink area, behind a removable panel
The ball valve is what opens and closes when you plug the shower head in. I can't see why there's 2 fuses for one pump. Have you 12v to the switch? Try plugging in the shower and operating the sink tap. Does water flow? It should
I do not have 12v to the switch
Plugged in shower hose , water flows via shower hose when sink tap is actuated
I’m hoping that there is a separate fuse for the shower, otherwise it could be wire/connector issue.
I’ll look for the fuse box tomorrow and update thread
