Shower and Tap Stopped Working
California_Clarky
California_Clarky
Southampton
T6.1 Ocean 204
I went to use to use the shower in my camper for the first time for over a year - I filled the van with water attached the shower at the back put the switch on and it made a werring sound and then stopped and is now totally dead ( the tap inside and the shower dont work) is this likely to be a new pump as I have checked the fuse and microswitch inside is working?
I do have an extended warranty on the camper - is this covered
Just had the pump on mine replaced under warranty. Error on the overhead console came up as well as the pump failing to work.
didnt see an error on the console mine is a 22 plate ocean
23 ocean here. When I ran the tap after a couple of seconds an error popped up on the screen, said something like error, consult service centre. Easily sorted by the dealer under warranty. Just had to wait 6 weeks as it went on the first day of a long trip. Sod’s Law.
Thanks for the updates guys. I will give my dear a shout in the morning. Hopefully that’ll be to sort it under warranty. It’s just annoying. I wanted to use it today.
UPDATE - there was a message on the console to day pump disabled please fill with clean water - this I did clicked the shower switch and it worked - turned shower off and went inside to try tap- tap worked but when I turned it off the shower can back on and I can’t turn it off any suggestions
