Leak VW 600
P
Proinni
Ireland
Grand California 600
My Grandcalafornia 600 is 4 years old. I’ve had water coming through one of the presses at the bottom of the bed on a couple of occasions with the past year. I’ve also noticed water under the toilet disposal container. It’s not always noticeable ( leak from press) except when I move or drive the van and only happens during heavy rain I think.
I have brought it to the Volkswagen garage where I bought it and they are bewildered as to where the leak is coming from. The skylight seals appear dry.
I would welcome any advice on this matter…..
The water under the toilet cassette could be where the adhesive has failed around the door opening surround. It's a known issue and can lead to the inner wooden frame rotting, which is what happened on ours (replaced under warranty). To replace the frame requires the complete shower unit being removed. There is a VW technical bulletin covering it which specifies a different adhesive.
Thank you for your reply ..will mention that to the garage. P
I will definitely be asking the dealership about this as I’ve been asking them about it for over a year and been brushed off. I think the ideal future van will be fully moulded or fully 3D printed as it seems that the joints and silicone seals the weak points. That and taps and steps. Still love the van just a shame that there’s not really a suitably trained and informed dealership network to look after it. I’d be happy for mine to go in local and be transported nationally to I get properly sorted. It would be quicker in the long run.
think you may be suffering from couple of different issues, first one already mentioned it the toilet hatch, check for cracks around the hatch frame. the leak inside at the rear bed could be the rear high level brake light seal, this was a recall notice so should have been done but check with VW. Finally if not the rear brake light seal could be the roof sealant is failing and allowing water into van.
Th
Thank you
Thank you
Thank you
