N
NickiandDoraCandyCopper
Hello there,
Well, I thought I was doing my best with keeping the van dry when not in use. When I was doing the usual checks, I noticed that the disposable dehumidifier plastic on the lower section was fractured and the sticky and quite caustic liquified contents had spilled into the cooker area and into the sink.
This caused a mess and also some very hard to remove staining on the stainless steel. Thought I would post to avoid others suffering the same mishap. If you use them, check the dehumidifier containers to make sure they are intact especially if you accidentally drop it before placing it. Another lesson learned
