P
parxuk
Hi
Unfortuntaly the motor in the fresh water tank of out T5.1 burnt out (big time). I have replaced the motor but on a couple of camping trips since when using the fresh water from the tank it is tainted with a bad smell/taste.
Following some instructions (a previous post on here and AI) I have completed the following to try and remove the odour:
Any other suggestions please?
AI mentioned fitting an inline active charcoal filter but dont know how easy this would be?
I would think replacing the tank would be a very difficult task and something I would rather not do if possible. With that being said we only got the van recently, dont intent to get rid of it for a very long time and would like to be able to use the frsh water tank for drinking water (amongst other things)
Very many thanks
- Replaced the hose that goes from the motor to the top of the tank (that the water is drawn through)
- Sprayed neat white vinegar on the insides of the fresh water tank
- Twice filled the fresh water tank with a 1/10 mix of white vinegar and water - taken the van for a good run to slosh the water in the tank then let it sit for 8 hours (AI recommended not leaving it longer as the white vinegar could damage any rubber seals). At various points with the solution in I have ran the tap to draw the mix through the lines and tap.
- Mixed 500g bicarb of soda with 5l of warm water. Thoroughly stirred the mix until bicarb was disolved then poured it in to the tank and filled to the top with normal water. Took van for drive to slosh mix around the tank and then let it sit for 5 days.
Very many thanks
