Hi I would be interested in it, if it’s an identical unit. Sorry for my ignorance what is component protection? Thanks
VW Infotainmentbsystems are electronically coded to the vehicles BCM , Body Control Module the vehicles electronic brain , so they cannot be used in another vehicle. The Component Protection has to be electronically removed for the unit to be used.
To remove Volkswagen (VW) Component Protection (CP), you must
re-sync the replaced control module with VW's official central database using ODIS software with valid GeKo online credentials. Component Protection is an anti-theft security feature built into Volkswagen Audi Group (VAG) vehicles. It triggers automatically whenever a "protected" module (such as an infotainment unit, instrument cluster, or gateway) detects a VIN mismatch. This mismatch immediately restricts or completely disables the part's functions.
Standard diagnostic tools like
VCDS or basic OBDeleven cannot remove Component Protection on their own because they lack authorization to access VW's secure backend servers.
Method 1: The Official Dealership or Specialist Route (Recommended)
This is the safest and most reliable way to clear the P02095 - Component Protection Active fault code without risking module damage or software corruption.
- The Requirements: A diagnostic technician must use a pass-thru hardware interface (like a VXDIAG Device) combined with ODIS (Offboard Diagnostic Information System) software.
- The Server Connection: The software connects directly to the VW AG factory servers via a secure GeKo login.
- The Verification: The database scans the donor part's serial number against global database logs to ensure the part is clean.
- The Final Adaptation: The system performs a Software Version Management (SVM) update, writes your car's VIN to the new module, and fully restores all locked functions.
Many independent VAG retrofitting garages offer this as a fast service. Providers like
UTL Performance or
Retrofit South West can complete the process in less than an hour.
Method 2: Custom Firmware Patches (DIY / Aftermarket Alternative)
If you are retrofitting an upgraded module (e.g., swapping a stock infotainment setup to a newer MIB2 or MIB2.5 system with Apple CarPlay) and want to bypass the dealership, enthusiasts often turn to customized software patches.
- Developer Mode Activation: The car's infotainment unit is put into developer mode using diagnostic tools.
- Firmware Update Installation: A custom toolbox software script is loaded onto a FAT32-formatted SD card and inserted directly into the car's glove box card reader slot.
- Green Engineering Menu Menu Patching: By accessing the vehicle's hidden "Green Engineering Menu", users can manually run a custom software patch that forces a "CP Off" command inside the unit's local operating memory.
- System Reboot: Restarting the hardware forces the local infotainment system to permanently ignore the background VIN checks
