Dippa
Ocean 6.1 - immediate heat doesn’t blow out any heat with setting 1, 2 or 3. I got it to work briefly with 4 but then couldn’t get it to work again after I changed it to 2. I’ve got my settings at 120 mins and only used or tried using it for 25 mins total!
Continuous heat - works fine but heat setting 3 wouldn’t work so had to set it to 4. I understand it uses the ambient temperature but my temperature was lower 12c. Once it reached desired temperature it switched off, which I expected but never came back on. I opened the door to let fresh cool air in to see if that would do anything but nothing!
Any help or advice in these is appreciated - thanks
Edit: just tried immediate heat again and it works on 6 but stoped after 20 mins - Does this only work depending on the ambient temperature?
