sidepod
- Messages
- 7,274
- Vehicle
- T4 PopTop
I’m curious? Just how much kit are you guys carrying around if you can’t find a bit of space for a short length of coiled cable?
Thanks Roger, I'll ask VW to check it when they do a service in June. I'd replace one of those fuses under the passenger seat, but the cube fuse on the battery sounds like it might be a bit trickier.The cube fuse in my cali T6.1 ocean had blown 2 months ago, I had only 50% of normal capacity until I replaced the fuse .
Our current cable is 20m and not that easy to coil, no matter what technique I try to use, or which youtube video I follow.I’m curious? Just how much kit are you guys carrying around if you can’t find a bit of space for a short length of coiled cable?
I guess even on leisure batteries there is at least 2y warranty ?I suppose I ought to have VW do the work if I were going to replace the batteries so as to not invalidate my warranty. Was that price using VW?
I had a new 4Motion Ocean. In 2022.There's a 5 year warranty ("5 year plus promise" marketing campaign, or something similar). I assume that batteries are included (unlike the kids toys).
It may well have been an issue from new! I've read on here before how some vehicles take a long time to arrive in the UK before they are handed over. I bought one of the last 6.1s as a stock vehicle, so I think that this might apply to me also. I didn't appreciate it at the time, but at handover the salesman didn't want me to turn the engine off while he was showing me around it. I expect that the batteries were low.
In fact it is easier.Thanks Roger, I'll ask VW to check it when they do a service in June. I'd replace one of those fuses under the passenger seat, but the cube fuse on the battery sounds like it might be a bit trickier.
Would it not take up less space just to carry a 20m hook up cable?Indeed : - )
You'd have to find the 12v plug and plug it in to said powerbank. There are some that plug the power bank into the EHU socket, though I understand that without a grounding plug, this can have a risk attached, so not my recommendation.
That doesn't sound that easy relative to my skills, tool chest or fear levelIn fact it is easier.
Empty boot.
Open access flap in base of rear wardrobe with a 2p coin.
Undo battery clamp nut/bolt at base of battery and lift out clamp.
Pull out battery using a paint scraper or dinner knife to lift up over the compartment lip.
NO NEED TO DISCONNECT ANY WIRES when moving battery into boot.
Check cube fuse on red +tve terminal with multimeter or just replace fuse . Normally 75 or 100 amp fuse.
In Cologne (Köln) last year, we ended up using our 25m+5m+adapter to the post and it still pinged like a piano wire!I always carry my 25M cable, I would say at least 5 times I have needed the full 25m. In Germany last year I had to run it under bushes etc to get it to reach!. Obviously you don’t need 25m all the time but when u need it u need it!.
It would, though you're then a) having to use pitches with EHU; and b) having to pay extra for the privilidge.Would it not take up less space just to carry a 20m hook up cable?
I think a week plus on AGM with solar would be expected too.How is there not a decent lifepo4 retro fit out yet?
You could get an easy week plus with solar etc
I believe there is.How is there not a decent lifepo4 retro fit out yet?
titanlithium.co.uk
Yes, that was one of the options I was considering. Also, when packing, it’s generally easier to find 2 small spaces to fill than 1 big space.Why don't you split the cable in half.? I carry 15m under bonnet battery and 10m in back. 10m usually enough.Now,you have 3 options. 10. 15. And 25M when needed.
This looks good. The link lists the advantages, but I assume that there are some disadvantages too? Otherwise, I suppose no one would replace expired leisure batteries with traditional (AGM?)? I really don’t know.I believe there is.
Drop in Lithium Batteries for Easy Replacement
Explore drop in lithium batteries options for convenient direct replacement. Learn how these batteries enhance performance and reliability.titanlithium.co.uk
AGM is proven reliable and safe battery technology. It allows for example to start the cali even at -25°C.This looks good. The link lists the advantages, but I assume that there are some disadvantages too? Otherwise, I suppose no one would replace expired leisure batteries with traditional (AGM?)? I really don’t know.
What I do.Why don't you split the cable in half.? I carry 15m under bonnet battery and 10m in back. 10m usually enough.Now,you have 3 options. 10. 15. And 25M when needed.
Take a length into the awning eh?What I do.
Also means you can get a splitter and take a length into your awning.
