Disappointing waste tank issues
  • Thread starter Almost bought a california
  • Start date
Kettering
T6.1 Ocean 150
When I bought my van (T6.1 california, 2 years old) I had an issue with the waste not draining. The tank was dry and not too dirty but what muck there was on the walls of the tank had dried and flaked off and so I cleaned the tank, unblocked the drain and have been very careful not to drop lumps or solids down the sink, I also drain the tank after use before adding a dishwasher tablet in a litre of boiling water which I leave in to swoosh around and clean the tank.
This has worked well for 2 years - or so I thought! It hasn't and so I hope my experience may help others here - and if you know better please feel free to share!
So I first needed to drain the tank enough to remove the access hatch - I chose to syphon the water from the sink inlet as the drain was well and truely blocked;
Drawer removed and the tool I knocked up last time to remove the access cover.
You can check the level with a torch, I removed the rest of the water with a big ass syringe which removed a lot of the dirt but the tank was was still pretty filthy,
is is the tool I made up the first time - I printer a much nicer tool and have included the STL files if anyone's interested - this cover was only hand tightened last time but I still needed the tool to remove it!
OK so the tank is nice and clean now but still blocked and you can see from the photo in the tank that the outlet is not accessible from here and the drain valve and waste connection are not easy to remove, it is possible to blow up the drain pipe from outside but first you have to remove the tank vent connected to the top of the tank and bung the tee to prevent the drain from flooding the van!
This photo shows the vent pipe disconnected and the tee bunged up with the blue pipe (the blue pipe has a bung in it and is just capping the outlet of the tee).
Vent hose back place - open up the drain and blow up the drain from outside - I'm lucky enough to have an airline and just used a rag to seal the drain so as to not over pressurise anything and cause more issues.
and Voila - the thank drains a bucket of hot soapy water faster than I can refill the bucket!
The new tool works a treat - printed with 3 walls and 10% infill.
I hope this might help and its worth noting that if your tank refuses to drain whilst you away its probably not the end of the world as the tank will drain via the vent / overflow - not ideal but it'll do until you get home.
I have also decided to change my waste tank procedure and I am going to try flushing 2 full bucket of hot soapy water through the tank after each trip and giving it an annual clean and check. I am going to continue leaving a litre or so of clean water to slosh around but I am going to try toilet additive instead of a dishwasher tablet as this will hopefully control any bugs and keep the muck in suspension.
If anyone has any proven, long term solution to this I would love to hear.
  • Waste tool.zip
I’d have thought one of those One Shot drain clearers would have been easier?
Heard a great tip in the MH world......buy a cheap bottle of coke and pour it into your waste tank whilst your driving between campsites. The vehicle motion / and coke will clean the tank.... rinse well
Sounds like a top tip!
I did think about this but wasn't keen about dumping this on the drive, also unsure what it might do to the plastic / paintwork around the drain point.
Thanks a lot for the post and files! I also wonder, what those different procedures will do to the pumbings and underside of the cali in long term. I use specialized waste cleaning agent and disinfectant once a year and when I drain the waste at home, I always rinse it with good amount of water as well. But it seems to me that it starting to drain slower.
In my case, I don't see the outlet on the underside like you do. When I drain the waste, the water comes from several places around the plastic covers there - maybe that is 4MOT thing? That's why I'm even more hesitant to put something like coke in there...
The waste water should exit via a clearly visible little hose on the near side. Unless your model is different.
Given this is the waste tank, as long as the union is free I’m pretty relaxed about the inside being dirty. It always will be. The worst ours gets is toothpaste water, everything else gets thrown in the bush. I know a lot of people faff around chucking dishwasher tablets in all their devices, but I’ve never found them that effective. Once a year we use a solution in the clean water tank at the start of season and let that swill around the waste one after before draining. Never been an issue.
This is what I get:
I'm starting to think, that I might be missing some hose there? Or is this normal for some model years? I have 2019.
This is what I get:
Mines a few years older but I’d be amazed if yours is meant to be like that. When you drive over a service point, the idea is you know where it’s coming from. Something amiss there I think.
This is what I get:
looks like your outlet hose is either detached or pulled up above the under tray. Draining the fresh water it comes out everywhere, but the grey water should come out in a single stream.
This is what you are looking for and should be able to see.
We use toilet fluid in the wastewater tank. Just like in chemical toilets, Solbio is an environmentally friendly version that also keeps the siphon clean. This fluid dissolves biological matter. It's economical, smells pleasant, and is harmless to the pipes.
View attachment 144091View attachment 144094
View attachment 144098View attachment 144099
Thanks for this
In South Africa we often Camp WILD, and never ever use the sink or the waste tank. I had a thought of using the Waste tank to increase my water store as we often (for 5 to 10 days ) have no access to water and have to carry everything with us. My question to you is how difficult would it be to modify the tank from Waste water to Fresh water....This tank is 3 years old and has never ever been used
Hope you can Help Bruce from Cape Town
Thanks for this
Hi Bruce,
the more I thought about this the more issues I thought of, your usage is very different from mine but I suspect there are too many negatives to make it a worthwhile modification. Much easier to add panier type racks to the outside of the van and use these for additional water containers?
