Control panel woes - Coast 6.1
L
Lauren@mcclemont
Eaglesham
T6 Ocean 102
Hi all,
I’m just back from a trip where I had my first ever problem with the control panel…
The first night was fine-I had driven over 100 miles so the leisure batteries were fully loaded. Fridge functioned normally and lights were ticketyboo. Diesel heater warmed us up a treat.
The following morning I spotted the fridge light on the control panel was off and when I checked the fridge contents it was obvious the fridge was not cool. I tried to check the control panel, but the screen only showed some blue lines, and I couldn’t do nothing with it. I popped the van on hookup to see if it made any difference, but even after a few hours the screen was still the same and my beer was getting warmer..
That night, I could no longer use the remote control for the diesel heater- but all the lights were still working.
On the way home I tried the screen again, and lo and behold it was working-but a new rear air con control had appeared (rear air con isn’t fitted and I’m nearly 100% sure this wasn’t there before). Fridge would function and diesel heater remote worked again - I thought it was a temporary glitch. That was until the following morning and the panel showed the blue lines again. After driving the van for may 20-30 mins, the panel then appeared correctly again.
I’ve pulled the appropriate fuses both next to the steering column and the one under the passenger seat, tested the leisure battery under the passenger seat (it’s fine) but haven’t managed to get into the battery under the wardrobe - could this be the cause??
It is weird as I don’t have to drive far for the panel to work again and when it does display it shows that I have 12.6v - I assume this is ‘full’.
Has anyone else experienced this intermittent problem, and if so how it was resolved??
