2011 Cali pop top roof fault 1000
marksea1205
Glasgow
T5 SE 174
Hi, I have the 1000 fault on my 2011 Cali and the roof will not operate now at all. I have seen in other posts that the roof can be raised by connecting
a 12V supply directly to the hydraulic pump. Does anyone have any pictures of how to access the pump connections?
Also I know there are some specialist garages out there but I am in Glasgow so if anyone knows any decent garages in the Scotland central area that
also might be an option. Any recommendations?
Remove Control Panel and on the rear, L hand side is a connector with 2 wires. SEE BLUE ARROW BELOW.
Connect these 2 wires to a 12v battery +tve and -tve . The +tve should have a 30 amp fuse in line.
Connected the motor will power up to either lower or raise roof. Just reverse the connections depending on what you want.
Sometimes clearing the codes and turning the controller off and on might work if you’re very lucky!
Thank you. I think part of the picture is greyed out but I see where you mean. So just need to remove some of the insulation foam to access it eh? I will get a chance to have a look in a couple of weeks.
Hi, I had seen posts about this and maybe even yourself. I can't clear the code as when I press the button suggested to clear the alarm it just goes back to the previous display. I think I will need to try the powering down option first if anything, thank you
Alan Gibson
Patrick T
tedgina
T
Taff2023
colintfcolintf
colintfcolintf
