I am no fysicus but guess keeps it soft and prevents the rubber from getting hard and stugg.
hotel california T5: just stunning what u put together, all this pics and great information. Wow! Awesome!
Nope , the table legs go in there ...not much room left , the area above is bigger and has bungeestraps....but also need to hold two table legs.The bottom section could be used as well!
Yes they do but need to be an expert in origamiI wonder if the front blinds would fit in there rolled up ....
As well as all the other kit, looks like you have a workbench, shelf unit/cupboard, Pepsi thermometer (?), something that looks like an early medical contraption and other assorted bits behind your seatDoes the job , table in place
Looks like you take it along in the back with youMy garage is 100m/square and has a attic on top ....but unfortunatly already no space left....
It holds lots of stuff i hardly ever use but can't part with , and sometimes these thing might come up handy...
It's a old bike hanging on the sealing and to the right a circular sawtable ( don' t know the correct name)
Also kind of DIY guy , so need lots of gear and goodies![]()
Elevating one?My garage is 100m/square and has a attic on top
Regulary check the holes that drains the water from the roof
Frontside the drainhole is underneeth this plastic cap
Remove it by holding it like this , sqeeze with your hand and pull towarts you at same time...like this .
Try to do it two handed but i had to hold my phone taking the pics..'
Clean underneeth and check te drainopening
Attention , don't push any sharp pin's ( like i do here with a nail) to deep in the hole , the rubber hose takes a direct turn and it will puncture the drain!
Use a ....how you call it ....thing to claen your ears stick
Backside is easyer and if you look good one can see light thru the drain if its open
About the same category :
Cleaning the rubbers of the sliding window(s) with a toothbruch specialy below, preventing dirt to get stuck and resulting in waterinfiltration.
As for doorrubbers in general use talkpowder no vasline or greasy stuff
Hello
Thanks for your tips about the drain holes especially the ones at the front.
After removing the plastic covers noticed that both the torx fixing screws were starting to rust as they were in a puddle of water see attached photos. Gave them a good clean & will be checking them on a regular basis as well as the drain holes.
Thanks again for the great information.
Steve
High pressure air line? Think that is what the dealers do. I had the same issue and couldn't unblock it myself. If you remove the A pillar trim then the pipe is clearly visible for that part of its run.Hello,
I have a blocked front drain hole (2006 California LHD) on the drivers side. I have so far not been able to unblock it using thin wire etc and water just pools in that area.
Any ideas welcome. Thanks.
I also had this issue (2006 LHD) - the problem is almost at the outlet -drain hose is bentView attachment 9497
I was cleaning the area that is normally covered when the roof is closed today, I could see the rear drain hole that drain down the back of the body that the tailgate covers but I couldn't see any drain holes at the front.
Could someone put a picture up, pretty please.
