The 3-seat-bench in the Beach seems to be the only one in the Cali range that you can't slide forward/backward without folding down the backrest first. What a pain! Has anyone found a hack to fix this?
Thanks Dave. Found it here: http://www.vwt4forum.co.uk/showthread.php?t=207271I have seen someone on the t5 forum who moved a spring on the bench enabling it to be moved with the back up on either a caravelle or beach seat. You would have to go on there and search or put a post on. It can be done though. Cheers Dave
I found a similar thread on the French Cali forum: http://www.t5calif.info/forum/viewtopic.php?f=27&t=3121&start=15I have seen someone on the t5 forum who moved a spring on the bench enabling it to be moved with the back up on either a caravelle or beach seat. You would have to go on there and search or put a post on. It can be done though. Cheers Dave
I couldn't get it to work. How do you create enough space to move your hands?The rope trick mentioned on the French forum works fine!
