snowy55
Awning LEDs
After reading this topic http://vwcaliforniaclub.com/forum/viewt ... 127&t=4379
I thought I would have a go. I purchased all the parts of Ebay.
This photo shows the lighter plug, 2 different dimmers, rotary and electronic, and the two wires with plugs and sockets fitted.
This shows the LED strip on the fixed side of the awning there is a similar strip on the wind out part. I used about 2 metres on each part, so I have about 1 metre spare.
This is the LED strip on the wind out part of the awning showing the socket and a short wire soldered on.
I didn't fancy drilling the body with permanent fitted wires, so I use either the boot socket or the socket half hidden under the seat behind the sliding door and run a cable through one of the dimmers to the first LED strip and then another wire along the folding arm to the other LED strip.
I bought the 2 different dimmers to see which I preferred, the rotary one in the photo is, off - click on, then progressive to full brightness but it doesn't go quite as bright as the electronic dimmer in the photo which also allows various flashing and "chasing" patterns if you want them! but as they cost very little it doesn't matter.
http://www.ebay.co.uk/itm/281199866036? ... EBIDX%3AIT
The electronic dimmer.
http://www.ebay.co.uk/itm/161471947850? ... EBIDX%3AIT
The lighter plug.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0163029013
The LED strip.
http://www.ebay.co.uk/itm/4pcs-DC-Power ... 2598514e38
These are the plugs and sockets used to join it all together. The LED strip comes with a socket already attached at one end, after you cut it to length you solder plugs and sockets on the ends of the strips as required, look on You Tube for how to do it. The rotary dimmer comes with a plug and socket fitted.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0236866026
The rotary dimmer.
The lighter plug.
The LED strip.
The rotary dimmer.
