motacyclist
Colin
This might be useful in really cold weather if you don't need the upstairs bed for sleeping -
Last night we jammed about the first 12" of a blanket under the upstairs mattress by wrapping it around the slats, so that it hung down vertically into the cab. Then I attached a strap to the front slat in the centre leaving it hanging down underneath the blanket; and pushed the bed up to the elevated roof.
Next, I put a bungie across roof of the the cab attached to the grab handles above the doors, and tucked the blanket into this, then attached the strap to the bungie in the centre and pulled it tight so that it made an upside down "Y" which supported the blanket; and tucked the ends of the blanket into the cab sun visors. This made an air barrier between the living area and the cold roof and vents at the top.
The living area was immediately noticeable more comfortable, and the difference could be felt by sticking a hand into the void space behind the blanket.
This left the only single walled areas of the bellow the two triangular side bits which we just stuffed two smaller blankets into.
Branderup £500, blanket £0. Took about 2 minutes to do! We just used what we already had in the van, but with a bit of thought something more sophisticated could be devised ... a project for the coming season?
