Frozen Van - Water tank discharged
Mountain-fish
New mills
Grand California 680
I might be posting this a bit early. I am living in my van but last night stayed at a friends and stupidly didn’t leave the heating on. The water tank has discharged and the kitchen tap is not activating…..will it be the truma valve that triggered and emptied the tank or a pipe that’s burst? The heating is working so it’s belting out to defrost the van sat in the sun.
I am going to fill the tank up once it’s warmed up, fingers crossed. Any advice welcome…….
The pump won’t work without water in the fresh water tank. Prob OK and will work once water is in the tank
Yes to what you've said and - you've probably found this by now - but make sure that the small blue button on the Truma is pushed back in, otherwise the water will just run out as you fill it.
