Wheels and Tyres
Good wheel choice! Look forward to seeing them on yours
This is the parts listing for TPMS for a 2024 California
(I would triple check before committing)
You can buy a repair set which is a kit for 4 wheels with everything.
You just need to ensure you buy the exact part numbers, there is a wide range of sensor types fitting method, housing profiles, pressure ranges, protocols and frequencies across VAG group over the years and can change even across model years when nothing else on the van does. I have seen and heard lots of people that end up with the wrong sensors because the after market and ebay sellers don't quote the correct vehicle compatibility, even sensors that look identical can have different protocols and don't work. (Hence must be correct part numbers)
LLL parts will check the part against your VIN number and confirm it is the correct part(s) before shipping. (Unless you tick a box to advise the part is a retro fit and therefore no checking is carried out ) .
Hi All, I’ve bought a T6.1 Ocean 150bhp 2024 with delivery next week. I didn’t like the wheels so I’ve bought some Sportline 18”x8J wheels. I need to order some tyres and TPMS valves (as it’s got direct TPMS fitted rather than ABS indirect). I’m looking at Continental All Season Contact 2 and the ubiquitous Michelin Cross Climate 3. I’ve also looked to get these pre coded TPMS valve stems from uk parts direct.
Questions:
1. Could someone post the tyre /wheel/B Pillar plate from a 2024 Ocean please
2. What have people found the above two tyres to be like in real world situations on a Cali
3. Anybody got any TPMS valve experience or recommendations
Thank you for taking the time to look and hopefully reply. Regards
I cant comment on the others as have all season bridgestone, just don't buy them as had loads of punctures from gravel or stony services. I have factory direct reading TPMS, they work, it displays on the dashboard if there is an issue and you can check the pressure via infotainment menu. If you swap wheels around they reconfigure to the correct position. Note only rely on the reading after the wheel has moved a few hundred yards.
Conclusion - just in case it's of use to others. VW system showed my build as having TPMS tyre valves fitted at factory. Braithwaite's (Penrith) were rightly sceptical as the fitted tyre valves visually appeared to be normal (non TPMS) valves. The van is MY24 with 6,400 miles, so highly unlikely to have had tyres/wheels changed. Apparently, some valves that look "normal" can in fact still be TPMS, so Braithwaite's did the sensible thing and unseated the tyre bead to look at the fitted valve internals. Result - Normal (Non TPMS) valves present! So, the learning for me is that the VW build sheet record may not reflect reality in relation to tyre valves at least. Good result for me as I can now simply exchange the wheels and tyres. Thanks for all the feedback and help from others.
Thanks for the tip. Appreciated
