Hole in Radiator
Bluestone
Bluestone
Cali now sold
So am I just the unluckiest person or has anyone else suffered this?
Got the health check from the dealer today and they say a stone has flicked up and put a hole in the radiator, they actually found the stone in the radiator so I guess this happened. I guess my question is how is the radiator so vulnerable to this? Has anyone else suffered from this?
I've not been 'off road' in it, driving normal roads, actually mainly to the supermarket and back. I'm a bit shocked this has happened to be honest.
Any thoughts?
Just happened to me.
Loss of coolent over the last couple of days. AA just been out and have a hole in the rear of the radiator. I'm assuming this is not covered by Warranty.
Jason
Jason
If its a hole in the rear of the radiator I would be trying for a warranty replacement, it wouldn't be a stone as that would have hit the front. A photo of the leak would help, its usually pretty easy to see if there are squashed fins where something has hit or just leak stains from a failed joint.
You can definatley see a few bent fins around the leak. When he presurised the system it was spraying out.
His gut feeling was they will refuse but if you don't ask you don't get.
This happened to me last Friday and the dealership has said not covered under warranty. In all the years I have been driving never happened in any other car.
I've just had a low coolant warning light.
On investigation I found the expansion tank to be empty at thas point the panic started to set in EGR cooler crossed my mind.:eek:
I removed the expansion tank lid and to my surprise felt a trickle of something warm running down my bare leg 'not an age related issue', I have found stone damage on the edge of the radiator and it will obviously have to be replaced.
My question is has anyone replace a radiator on a T6 Ocean and if so how big a job is it.
Replacing the main engine radiator on a Volkswagen Transporter T6 requires removing the front bumper assembly and front support structure to access the cooling pack (which includes the AC condenser, intercooler, and charge cooler). [1]
Required Tools & Parts
    • Torx drivers/bits: T25, T30, T40
    • Sockets & spanners: 10mm, 13mm, 17mm
    • Pliers / Hose clamp tool & 90-degree picks
    • Plastic panel-clip removal tool
    • Axle stands or a vehicle ramp & drain pan
    • New coolant (G12evos/G13 compliant spec) and a replacement radiator [1, 2, 3, 4, 5]
Step-by-Step Overview
    • Preparation: Ensure the engine is completely cold. Raise the front of the van safely on axle stands or a ramp and open the bonnet. [1, 2]
    • Remove Under-trays and Wheel Arch Liners: Undo the Torx screws (T25/T30) holding the wheel arch trims and the 13mm bolts securing the lower engine undertray. [1]
    • Remove the Front Bumper:
      • Disconnect any front parking sensor wiring plugs or headlight connectors as you pull the bumper loose.
      • Having an extra pair of hands helps maneuver the bulky front bumper away safely. [1, 2]
    • Drain the Coolant:
      • Locate the lower radiator hose or temperature sensor clip.
      • Place a drain pan underneath and remove the horseshoe clip or hose clamp to drain the coolant. [1, 2]
    • Access and Clear Ancillary Coolers:
      • Move or loosen the air conditioning condenser and intercooler/charge cooler components carefully without kinking or puncturing the A/C lines (you typically unbolt the condenser/intercooler from the core support rather than degassing the A/C system if you swing it aside). [1, 2]
    • Remove the Old Radiator:
      • Undo the upper and lower radiator mounting bolts (T30 Torx).
      • Disconnect remaining top/bottom coolant hoses.
      • Lift the old radiator out of its lower rubber grommets/support housing. [1, 2]
    • Install the New Radiator:
      • Transfer any rubber mounts, clips, or the temperature sensor from the old radiator to the new unit.
      • Drop the new radiator into place, reattach the upper/lower brackets, and connect the hoses. [1, 2]
    • Reassembly & Refilling:
      • Reinstall the intercooler, support panels, and front bumper in reverse order.
      • Refill the expansion tank with the correct coolant mixture and bleed the air from the cooling system properly. [1, 2, 3]
Note: A typical garage or mobile replacement in the UK for a T6 radiator generally runs around £252 to £486 total if you prefer not to tackle the bumper removal yourself. [1]
Thanks for the information, looks more likely a trip to the garage as even the bumper removal on the drive has potential for paint damage for a single person completing the task.
Intercooler and charge cooler? They’ve always been the same thing since the dawn of time.
Gotta love AI
Any thoughts?
Has it actually caused a leak? It’s very easy to get a stone lodged in the foil fins between the core tubes but to actually cause a leak?
I’d ask to see the coolant dripping from radiator!
Gotta love AI
Intercooler and Chargers Cooler might have the same function, but they do it in slightly different ways.
FeatureIntercooler (Air-to-Air)Charge Cooler (Air-to-Water)
Cooling MediumAmbient AirLiquid Coolant -> Ambient Air
System ComplexityLow (no pumps or extra fluids)Higher (pump, lines, extra radiator)
Turbo Lag / ResponseSlower (due to long charge pipes)Faster (shorter path, manifold-mounted)
Best Use CaseDaily driving, track days, sustained high-speed runsStreet cars with tight packaging, drag racing
Gotta love AI
Hi, it is a a gush not a trickle it dropped 4 ltrs in less than a minute, this is a picture of the stone that I removed, a big thanks to capita or one of their contractors for throwing it into my path with the grass cutter
A bottle of Radweld won't fix that I'm afraid.:headbang
