Got the same cracked EGR pipe issue so hijacking this thread in search for advice.
Somewhere while going down the west coast on the NC500 the rear EGR pipe decided this was absolutely the perfect opportunity to burst. Fortunately, the split didn’t grow and we got home otherwise unscathed. But what a trip – 2000k miles and the most enormous fun.
No warranty on my van, so I now have the task of replacing the pesky pipe .. kit on order from VWvanpartsdirect and luckily one of the Erwin chapters I managed to download was for replacing the EGR rear pipe
but there wasn’t time to grab the other cross-referenced chapters before the cutoff kicked-in and everyone’s access got terminated
From the chapter I have, the steps involved don’t appear especially complex, but if anyone has done this on a 204PS Ocean I’d be grateful for any insights especially aspects from chapters I don’t have.
Remove expansion tank – should be straightforward, assuming I’m able to plug the expansion hose on the underside quickly and stop too much coolant from the top half of the system escaping – wine cork or conical bung might do the trick.
Remove gearbox oil cooler with attached coolant hoses and lay aside – presumably this means remove the bolts (from above I can only see two) holding the cooler while leaving the hoses with oil in still connected allowing it to be moved to one side and make space. With the expansion tank out of the way hopefully reaching the bolt next to the EGR cooler through the maze of pipework above becomes easier.
Loosen selector lever cable on gearbox only and lay aside – haven’t yet put the van in the air to find out how the cable is attached, but once I can hopefully it’ll be evident, although fully expect it also won’t be simple as not much seems designed to make anything easy in the slightest.
It then goes on to explain removing the split pipe has to be done from above and below, and new pipe must be installed
free of stress – presumably the pipe needs stretching slightly before everything aligns.
To achieve this start all bolts hand tight and tighten them diagonally and alternately thereafter - the way I ended up interpreting this is, as the bolts are located diagonally in the flanges anyway, first partially tighten the two on one flange and then the two on the other. Then, in the same sequence as you would a road wheel, tighten each alternately to 20Nm i.e. in the sequence below. Can anyone confirm this is the right/wrong approach?
After which aligning the pipe requires loosening both bolts going into the EGR valve and retightening them, followed by the two in the exhaust manifold, then refit everything and top up coolant with G10 Evo.
Advice will be much welcomed!
