T6.1 fresh water level indicator
I was just reading through these posts as my water level doesn’t seem to register.
Could you advise how I get to the pump etc as shown in your photo please? I had a look in the rear wardrobe area and couldn’t identify anything that looked like your photo
You can access the tank by removing the plastic disc bottom left of the wardrobe and then undoing the circular lid underneath which is screwed down tight and has wires lying over it. Hard to remove but can be done with a special tool from the club shop or by using a wood block drift and a mallet to loosen it (anticlockwise). You can then see the pump etc as shown in the photo.
Great, thank you. Will give it a go when it cools down a bit out there!!
I’ve got intimate knowledge of the fresh water system level detection on various trains (don’t ask…) which cost considerably more than a Cali and don’t work that much better.
I had an issue with my fresh water level indicator (T6.1) where the control panel continuously indicated empty, regardless of the actual level. Sometimes the tap would work, sometimes it wouldn't. Had a look today in the tank under de wardrobe and removed the float/senor. Turns out the pump was installed incorrectly, able to move around freely and stopping the float from moving up with the water level. Moved it to the corner where there are 2 tabs holding it in position and out of the way of the floater. Works perfectly now. I have attached a picture of where/how it should be installed. Hope it helps for those strugling with the same issue.
This fixed my sensor problems. Thanks good work.
When the fresh water tank is completely filled the display will not show a full tank, see the picture. I still have to open the tank to inspect the sensor to see if it is caused by the pump as described earlier in this thread.
Since others mention the level measurement is not very accurate I'm even considering intstalling an additional level measurent.
The Mopeka ultrasonic sensor with bluetooth app is interesting but must be installed 3" from the tank wall. I asked them if that is a hard requirement since such a accesable location on the tank is not available.
Votronic has a conductive sensor with a wired display in steps of 10% of the total tank capacity.
Hose pipe in the filler neck. When it spills out it’s full. I don’t think I’ve ever consciously looked at the on screen level.
When the pump noise changes I know it’s empty.
I know that’s a simplistic view but how accurate do you need it?
With 200Ah LFP batteries and solar our water is now the limmiting factor when we are camping wild. So a good indication of the actual level is more important than just a nice to have.
The capacity of the water tank is the limiting factor when wild camping not the level sensor . We take a small extra , transparent water jug (5l or 10l) when wild camping. When tank runs empty we can see how we use to the last drop from the jug.
