Pop top heating
johnw6379
Wales
T6 Ocean 199 4 motion
Pop top heating, I'm sure this has been done but I think this is more simplified, all you need is duct and a plastic bracket,
The brackets I just melted over a stove and bent with long nose pliers then cut to suit, then held in place with white duct tape,
Easily folds down to next to nothing and supplies a generous amount of heat upstairs
I made a similar thing but in the end the smell of 'over warm plastic' was too much of a concern for us. It seemed ok in mild weather when heat was questionable any way and when it was really cold we found it did'nt work as well as desired or the plastic tube became dangerously hot.
In the end we just settled for an extra duvet and/or simply leaving the heating on downstairs. Or if too cold we would sleep downstairs anyway (which we did all round Iceland in April, where it was cold and too windy for the pop top)
Ah ok not tested it on full heat but I appreciate the concern I may moving forward use an aluminium duct, although this ducting is used on tumble dryers and the heat from that is on par I think, but I'll monitor as I go
Get a thicker duvet.
You can heat it but it escapes straight away. When we had young kids downstairs and wanted to warm it for them we would shut the hatch 90% to keep the heat in downstairs.
Or if you are on hook up, use an electric blanket. Game changer in our van!
Fit a brandrup isotop internal liner. Retains heat in the winter and keeps the van cooler in summer.
I would say the same for our external one - never had a winter issue since we started using. Or, we sleep down instead.
