New Engine?
That's a good one, I haven't seen that one before. I would say that one is more evidence towards number 1 of @Velma's Dad post. Especially the bit about finding a bit of aluminium stuck in the piston top. Looks like it's big chunks in that case though rather than dust or whatever, might explain why it goes from bad to quick so fast.
Yep. We can scratch our chins and debate about varying aluminium traces in oil, what level is abnormal and what damage that might do, and about the lack of any good data on incidence levels etc etc.
But my (non-engineer's) brain simply looks at the those photos of coolers with big chunks ripped off the fins and thinks, well those chunks could only end up in one place. Fire great shards of anything metallic into a combustion chamber and major damage is almost inevitable. An EGR component that's capable of getting itself into that state under any operating conditions is (for me) evidence of a very problematic bit of design engineering.
I've booked my 180 in for an EGR replacement as a risk reducer.
Just a reminder that this last case of EGR failure on a 2016 180 was with a D EGR cooler. But maybe you would get at least 6 years’ protection by changing it.
Or you could simply fit a Tafmet and blank it, much cheaper option.
What was the outcome in the end? Mine is just about to hit 60k and oil consumption has recently increased
I'd love to know more about a tafmet
The Tafmet is an EGR emulator, it makes the ECU think that the EGR is still working, that allows you to blank the inlet and outlet ports with the thin blanking plates.
The result is no more risk of aluminium contamination.
I'd suggest getting an oil test by Millers to determine the level, if any of contamination.
Unfortunately if oil consumption has increased it's likely that some damage has already occurred. A reminder that 180 owners should start testing oil now, even if there has not been any oil consumption increase. Think of it as preventive maintenance.
I was lucky, I did not become aware of the potential problem untill much later than I would have liked. Fortunately I still had no oil top ups between services and I had ignored VW service intervals, my Millers oil test came back ok. That's when I fitted the Tafmet, sold the van at 150k to a friend of my sons, confident I caught the problem in time.
I'll definitely look into this and potentially getting a tafmet fitted, if it's not too late. Who are millers? Sorry as I'm far from a maintenance expert
Millers is a oil company will also do oil analysis on customer samples.
I use them for Motorsport engines but have also had my van done.
You order a kit and take a sample of oil from the engine (before engine has an oil change) and post it to millers, you will get a report back in a few weeks via email including any concerns.
Are there any specialist in the NW or west mids who fit a tafmet, would anyone know
I found the easiest way to get the oil sample was to use a small diameter tube and a syringe via the dipstick opening, make sure the tube is long enough as you certainly do not want to drop the tube into the engine.
Maybe worth taping a stopper on the outside of the tube.
Can't recall the exact amount but it was a couple of syringes worth.
The form you complete with the sample asks about the milage on the oil, this obviously affects the result, best if the oil has some decent milage on it.
I did the same extraction method, I just used the dip stick as a reference length, I also used a bit of wire down the middle of the tube to help it get into the correct place (ie not curl up) and removed it before taking sample. You have reminded me, they also ask for the oil make and spec as well as the engine type and mileage as you remembered.
