Water pump /tap fuse winterise
Brianandjoy
Somerset
We’ve just exchanged our 2016 for a 2023 California,I want to winterise it soon and take out the fuse to the tap so I can drain it.Can someone send me a picture of which fuse it is and where it is so I can i can pull it and drain the tap,it was easy on the 2016 but the new van is very different
Fuse diagrams in the Resources section.
i believe the water pump on the T6.1 is driven directly by the special vehicle ecu that controls the campervan stuff and not via a fuse. You might find it easier to unplug the tap switch connector and then open the tap.
Where is the tap connector please
Where exactly is this in the van please,
Open R kitchen door. Remove cutlery draw.Feel up alongside the R side of the sink between the sink and the R wall of the kitchen unit and you will find that connector wrapped in foam. Undo the connector and the tap and pump are disabled.
Mama Mama
flying banana
flying banana
James Worsley
Maxi-Mizer-T6
Maxi-Mizer-T6
