Fitting a DC - DC charger in my Cali!
Swiftflare
Swiftflare
Salford, Lancashire
T6 Beach 150
Greetings all, I am struggling to find where to put a DC - Charger (bluetti 2) in my beach, bed needs to be used and not sure where to run the cables if fitted in the rear? Ps not purchased yet so suggestions are welcome for alternative as there is already a leisure battery fitted under passenger seat and the diesel heater outlet under drivers seat ?
Thanks in advance
Where are you going to store the power station ?
Remove the plastic factory seat base cover and replace with a board ,
attach Dc charger to the face so you can access it.
Enables Shortest run of cables etc.
Cheers never thought of that, the power station will be portable as I use it as a day van so connection should be fine.
Do you think it will have enough clearance as the seat swivels?
Check out the size of the board or the floor the top of existing plastic cover, If the Charger is smaller it shouldn't be an issue.
Send an update with some photos to help others when it's done
Cheers, will do, getting measurements of the unit, bluetti charger 2, I have a ecoflow delta 3 , as it will cope with other power stations in the future
EcoFlow does a universal one as well, mine is under the drivers seat. Loads of room.
Not the best photos but it’s one from the front of the seat and one from the rear. If you can get the 800watt version it can be used direct into the EcoFlow battery port or using an XT60 cable for most other and EcoFlow power stations.
thanks for the pictures, I have decided to try and fit it under the drivers seat as there is more room even with the trunking for the diesel heater.
