Fitz@CFB
After 8 years I apparently need to replace at least one of my leisure batteries on our 2018 Ocean - poor performance in one came up on a service health check. I decided to source and do the replacements myself. There are very helpful how to U-tube videos by Campervan Bits. I am not going crazy so will replace with traditional lead acid rather than spending a fortune on Lithium etc. Before I purchase a couple of questions have arisen which I am sure some of the experts on here will be able to help answer:
A couple of the product specs I have read say if I have 2 leisure batteries I should replace both at the same time - is this advisable? Only 1 was identified as weak but I assume after 8 years it won't be long before the other one also starts to fail.
I assume I can 'upgrade' from the factory fitted 70amphour units to 95s? The physical dimensions are the same and I think it just means they would have slightly longer life under load.
I have 2 of Roger Donahue's roof mounted solar panels connected to the rear battery. Does having solar make any difference to the type of replacement battery I should go for - I assume not but just wondered if any battery tech changes make some types better with solar than others.
Many Thanks
fitz
Many Thanks
fitz
