crookrise
If, as you say, the roof works OK when on electric hook up then its a battery problem. Possible a cube fuse blown on top of one of the batteries.
As a side you dont need the engine running to put the roof up or down but you do need the ignition on.
Reason for ignition on is so as the vehicle speed sensor is active to check if the van is moving.
